Old 18-Jan-2011, 9:53 PM   #2
Tower Guy
Originally Posted by aquajon View Post
I would love to get an antenna recommendation. I would prefer to spend less then $50 on the solution.
A ANT751 will work for you, but you should decide to aim it at Miami or West Palm Beach.
Another possibility is a HD1080. When aimed at Miami, it should also get WPEC and WPTV.
In the attic I would consider a homemade antenna http://imageevent.com/holl_ands/multibay/4bay or http://www.tvantennaplans.com/ without the reflector as it would pick up the UHF stations in both Miami and West Palm simultaneously. Add a small VHF Y5-7-13 and UVSJ for either Miami or West Palm Beach, depending on if you want WSVN and WPLG or WPEC and WPTV.
