Thread: No Better Off
Old 15-Nov-2015, 7:55 PM   #10
Question; In order to bypass the preamp, is it sufficient to just unplug the power or will I have to get up to the antenna and move the cable from the output of the preamp directly into the antenna
You will need to do both as the former simply turns the un-powered amp into an attenuator. You can leave the un-powered injector installed as long as you're able to accommodate its small (<1 dB ) insertion loss.
