Old 14-Nov-2015, 11:23 PM   #7
I also get channel 60.1 Ion about half even though the DB8e is pointing at 122 mag. This encompasses six channels including a kids channel.....Could I add another antenna more catered to this signal and combine it with the other antenna?
Add another antenna for VHF-High because ION is on real channel 12. Combine the two antennas with a UVSJ.
ION is a lot weaker than your core channels, so you need a VHF-High antenna with some gain. You can try the MCM 30-2475:
http://www.mcmelectronics.com/product/30-2475
The ION signal has a 2Edge path because of terrain interference:
http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d8
Your FM report shows WQWV on 103.7 MHz with a signal power of -25.0 dBm, which is 65.1 dB stronger than ION. Channel 12 is 204 to 210 MHz, and the second harmonic (2x) of WQWV is 207.4 MHz which falls on channel 12. You should add to your order two FM traps:
http://www.mcmelectronics.com/product/33-341
If that doesn't work, you will need to add some amplification.
I don't know if you are using an amp now. I don't know how long the coax line is.
I don't know how many TVs you are feeding.
I don't know if there are any trees in the signal path.
