The good news is that all your local stations are coming from the same direction. You just need to point your antenna at compass heading 148ยบ.
BTW, the MXU47 is a UHF-only antenna (channels 14-69). The high gain and tight antenna pattern for this antenna will surely perform better than your saucer antenna.
Please note that this antenna is not designed to pick up VHF channels (channels 2-13). K05KX (translator for KWVT) appears to be the only VHF channel in your neighborhood, and it's pretty strong, so there's a chance that you might get enough signal through your antenna to make it still watchable. If not, then you may need to add a VHF antenna or switch to a VHF/UHF combo antenna.
