Old 13-Nov-2015, 8:09 PM   #24
WIRELESS ENGINEER
The Xtreme signal antenna HDB8X from Solid Signal at $49.95 is pretty hard to beat for high performance on a budget
The dual 4bay bowtie design allows high gain and wide beamwidth so you can usually get by without expensive rotators
Be sure and feed it with RG6 coax and keep the distance as short as possible
If you need a preamp you can always add one later
And no you can't trust the fabricated mileage and gain claims of most companies
