Thread: cant get FOX?
Old 12-Nov-2015, 2:40 PM   #2
Tim
Are you speaking of FOX WALA on real channel 9? What kind of antenna do you have? What kind of "signal boosters" do you have? Where are they mounted? Are you feeding one TV directly or splitting to multiple TV sets? What type of cable are you using? Are there any trees or buildings in front of your antenna? The more information you can provide about your existing installation, the easier it will be to make some constructive comments.
The first thing that jumps out at me from your TV Fool report is that WALA is on the Hi VHF band while are your other stations above it on the report are UHF stations. Is your antenna capable of VHF-Hi reception or is it UHF only? Also, WALA is quite weak at your location.
