Thread: No Better Off
Old 9-Nov-2015, 1:39 PM   #5
agmccall
Sorry to hear you are having trouble.
What direction? Should be 92 degrees magnetic. According to previous thread I should be pointed79 degress, basically east
Where is the power inserter for the 7777? Preamp mounted to mast below the antenna and power inserter is in basement
Are you using any other amp besides the 7777? No
What direction is the RCA aimed at? Are you using an amp with the RCA antenna? Almost East maybe 5 degrees south of east it is powered
I agree. Something is obviously wrong, but I haven't figured it out yet.
Where is the 7777 mounted, near the antenna? About 12" below anetenna
How long is the coax run from the antenna to the power inserter? 50' I could probably shorten it by about 10'
I wonder if the inverter is causing interference to TV reception?
Thanks for reply
al
agmccall is offline   Reply With Quote
