Could you please post a link to a tvfool analysis for your exact location? That will help us figure out what stations are within range of your location.
The amplified saucer antenna has a built-in amp, so it needs a power supply to drive the internal electronics. Do you have the power supply hooked up (and correctly)?
Are there any splitters between the power injector and the antenna? If you do, you might be sending power to places you don't intend to, and it might also result in insufficient power being delivered to the amp in the antenna.
