Hello Rabbit73,
I considered 2 antenna's briefly, but most of my research seemed to indicate that a two antenna solution could be fairly difficult to pull off.
When Spring 2016 arrives and the mature trees in my neighborhood have all their leaves again, I am concerned that they could cause considerable multipath interference.
One person I spoke with recommended the DB8e.
Is there a two antenna solution you would recommend?
Thanks
