Old 8-Nov-2015, 8:56 PM   #29
I see two potential problems, interference from your solar panels or a problem with the scanning function of your TV set. When you pick up CW on 2.2 you should also get NBC on 2.1. When you get CW on 45.1 and 45.2 you should also get 45.3 (CBS). Try the double rescan process suggested by the FCC by disconnecting your antenna from the TV set, unplug the TV set from the power source and reconnect it, and then rescan for channels. It should find zero channels, next reconnect the antenna, unplug the power source, reconnect the power, and scan again. Then report the results.
If your antenna is close to your solar panels you may want to move the antenna as far away from the panels as possible.
