Old 8-Nov-2015, 4:43 PM   #20
scott784
Yes, but, based on a recently purchased sample, it's largely ineffective below 100 MHz.
You need a full-band filter as all your local strong FM signals are in the lower half of the FM band.
So I now understand a full band FM Trap can help. And rabbit73 previously shared the following link:
These are so inexpensive. Is there a recommended full band FM Trap that I could buy at my local Home Depot, RadioShack, or other electronics store versus paying for the shipment of such item online? Also, where in the coax line is it generally recommended to install these full band FM Traps? Does it need to go right at the antenna before any preamps or anything else? Thanks.
scott784 is offline   Reply With Quote
