Old 18-Jan-2011, 1:08 PM   #4
John Candle
Tv Antennas and Reception
Mount a Winegard HD7694P and Winegard AP8700 preamp above roof top. Point the antenna at starting direction of 365 degrees--North and see what is received. The channels to receive are , WADY 21 ABC , KFME 13 PBS , KXJB-DT 38 CBS , KVRR-DT 19 FOX. . . K49FA 49 is second PBS - You will not be trying to receive K49FA . The reason is it is to far off axis from the front of the HD7694P antenna. You are aiming to receive the listed channels from WADY 21 to KVRR 19. The spread is wide between 21 and 19 -- maybe too wide. You will be turning the antenna to the left and right to find a place to get them all if you can. If the one antenna does not receive all of them then you will have to install 2 antennas. The stations starting with KDLO Channel 3 and on down are not receivable at your location. . Read and understand this about Real Digital Tv Channels and Virtual Digital Tv Channels , http://forum.tvfool.com/showthread.php?t=695
