Old 8-Nov-2015, 12:29 AM   #12
Unbelievably, WGHP was still pixelating...moreso than at a lower level in the house!
Are there objects outside that block the WGHP signal when the C4 s in the attic, like trees or other buildings?
And with this setup, the DB8e has the same issues as it relates to WGHP.
Is that when the DB8e is aimed at WGHP or SW?
Does the TiVo have a diagnostics screen that gives signal strength, SNR, and uncorrected errors to help you find a good location for the c4?
Are you using an amp?
