Old 6-Nov-2015, 10:42 PM   #6
scott784
How about simply splitting the signal from the DB8e and also feeding that set that currently has the C4 on it. The C4 then can be re-purposed to someone else who can use it..
As I mentioned at the beginning of this thread, my question is not about splitting the signal of the DB8e. Actually, that was my original intent with the DB8e; however, due to space limitations in my attic, I am forced to keep the DB8e faced to my south (both panels of the DB8e) (for the Charlotte stations)....versus having one of the panels facing SW and the other E-SE for my true locals. And with this setup, the DB8e has the same issues as it relates to WGHP.
But I have moved beyond that; and I am only asking about the C4 in this thread (not about the DB8e) and (not about splitting any signals). That's why I said I have two separate TVs with totally separate wiring.....and the way I plan to keep it at this time. I also don't want to repurpose the C4; because I want to use it on my downstairs BR/office TV for my true locals only on a single TV. And the downstairs BR/office TV using the C4 is what this thread is about.
Fortunately, I am in a situation where I 'can' get the wiring up to the attic for a second antenna (the C4) for my other TV/receiver. I will run some test wiring before I do it. However, I was only posting this current thread to gather any insight from others as it relates to multipath issues. Thanks.
scott784 is offline   Reply With Quote
