Old 6-Nov-2015, 6:28 PM   #15
cspartan
Thanks Rabbit. I will look into the HD7694P.
About the grounding wire. My home eletrical system ground is on the complete other side of the house from the antenna on the garage. Is it ok to run a length of copper wire that far? Can I bury it? What about putting in a separate grounding rod behind the garage and using that instead?
cspartan is offline   Reply With Quote
