How many Tv's will be connected?? I suggest All New Coax Wiring. Do the coax wiring this way , At a easy to get to place will be the central point that All coax wiring goes out from , from the central point a single coax wire will go out to each Tv location and a single coax wire will go to the antenna. At the central point will be the splitter and at the central point needs to be AC power for distribution or antenna preamp.. If you were to install one antenna , what city do you identify with Indianapolis or Cincinnati/Dayton?? . . If you were to install 2 antennas one pointed at Indianapolis and one pointed at Cincinnati/Dayton then you will need to install double of every thing. You will have 2 separate systems. Do Not connect the 2 antennas into one coax. With the 2 separate systems you will have a Remote Control A/B antenna coax switch at each Tv location. Radio Shack has remote control A/B switches. Before we go any further , How many Tv's will be connected??
