Old 10-Feb-2010, 9:01 PM   #1
seashipsink
Need new antenna?...and other problems
Here is my report http://www.tvfool.com/?option=com_wr...27ee092f192463
I have been using this antenna JENSEN TV-631 to receive OTA signals and I get the following channels:
KREMDT - 2.1 - CBS
KXLYDT - 4.1 - ABC (somewhat weak signal, all 4s)
KXLYDT2 - 4.2
KXMNLD3 - 4.3 (mirror of 4.1)
KHQDT - 6.1 - NBC
KHQDT2 - 6.2
KHQDT3 - 6.3
KSPSDT - 7.1 - PBS
KSPSDT2 - 7.2
KSPSDT3 - 7.3
KSKNDT - 22.1 - CW (somewhat weak signal)
KAYUDT - 28.1 - FOX
KAYUDT2 - 28.2
I have a Visio LCD and a Hauppauge HVR-2250 as my two main TV tuners.
When I scan channels with the Visio and the HVR-2250 there are quite a few more channels listed in the guide but I only receive the above channels with any signal at all. Also, when I scan with the Visio all of the 4s have 2 copies of each listed in the guide but there is only a signal on 1 of each (the signal is reliable and rarely cuts out). The HVR-2250 on has only one copy of each but I barely get a signal and have to wiggle the antenna around to be able to (barely) watch the channel (it still cuts out often). Why might that be?
The local PBS station has recently switched over to a better signal and according to the website the channel has changed to 8.1. However when I scan with either tuner it still lists it as 7.1. And ever since the change my HVR-2250 has been unable to receive the channel at all. It used to be one of the best signals I received. Any other standalone TVs receive the signal fine (albeit on 7.1 instead of 8.1).
Any recommendations on these problems or on an antenna that may solve some of these would be much appreciated.
seashipsink is offline   Reply With Quote
