Old 6-Nov-2015, 3:22 PM   #56
Tim
Originally Posted by kenj66 View Post
Tim, perhaps there is a better sealing tape to use. I used the Scotch one inch wide Professional Grade #2228 Moisture Sealing Electrical Tape. It definitely is up to the job! Trouble is I have to razor knife the tape and reef on it hard to get the stuff to come off.
The silicone fusing tape I recommended is easy to remove as it has no adhesive. You apply it like tape and it sticks to itself. Over a couple of days time it fuses into one solid coating of silicone rubber. You can slit it lightly with a razor and it peels off easily.
My neighbor (an auto mechanic) had good success waterproofing his antenna connections with Permatex Dielectric Tune-Up Grease that is available at many auto parts stores.
