Old 6-Nov-2015, 1:34 AM   #13
I would recommend a DB4e mounted to the chimney aimed directly across the swimming pool.
I will also recommend trimming the tree limbs to the left and also turning the trees directly beyond the pool into firewood (if you own them) so as to create a gap for the signals to get to the antenna. If you do not or cannot do this, your reception WILL be at the mercy of the trees and all bets are off.
