Old 5-Nov-2015, 6:14 PM   #14
Could the trees, hill and tower be causing multipath issues that the MCE tuner can't handle, but the Vizio can?
Yes, multipath issues and weaker signals.
Would putting a larger Yagi antenna (like a CM-3018) or a bowtie DB8 solve this issue?
The 3018 is a huge antenna that covers VHF-Low, real channels 2-6, which you don't have. The DB8 is UHF only, real channels 14-51. I suggest the Winegard HD7694P combo for VHF-High and UHF, as an upgrade from the 751.
Add a Channel Master 7778 preamp near the antenna to amplify the signals before they suffer the 100 ft coax loss. Once a signal is lost, an amp inside can't recreate it.
You could try the CM 7778 with your RCA 751 before buying the 7694 antenna.
Code:
7694 > 7778 > 100ft RG6 > grounding > CM power > splitter
                          block       inserter
So I kind of gave up on this as the wife wasn't pressuring me for DVR capabilities on the MCE machine, but now that's a request so I'd like to try to get a reliable signal back into my MCE box.
If the upgrade works well for the Vizio but not the MCE, consider a TiVo Roamio or a Channel Master DVR+.
Thoughts on a bigger antenna solving my issue?
Chances are good, but no guarantee when trees and hills are involved.
