Old 5-Nov-2015, 4:36 PM   #10
SusanS
Yes, but I would like ADTech to double check my analysis in case I overlooked something. There are many factors involved, so you will need to continue with the experimental approach. I don't want to waste your money, so you need to go step-by-step.
Okay
Chimney is in okay condition, but I think the eave would be better.
I hadn't returned the other antenna and was able to get some cable (recycling center) and rigged up the antenna using a ten foot electrical pole. I was able to approximate the location the antenna would sit. I got only the very local station. Although I didn't have the booster on.
I returned the antenna, as customer service failed to assist, and who needs that headache.
Would you like me to take a picture and attach here? Would that help?
Thank you so much.
SusanS is offline   Reply With Quote
