Tigerbangs,
Thank you for your help and insight. It appears that an upgrade in antenna is in order as the two stations i would most likely watch are 5 and 7. These two are giving the most problem with intermittent reception.
What I find odd however is that having the antenna pointed at 68-70 degrees, I pick up both Prov. 12 and 64 without any issue at all. (strange)
Thanks again,
Bob
