Old 5-Nov-2015, 1:05 PM   #16
bimr8
antenna mount location and interference
I've attached 3 photos. The 1st shows the antenna and its direction, the 2nd and 3rd show what it's aiming towards, unfortunately the camera shots have been taken at ground level and it's hard to get a good long-view. There's light tree vegetation in adjacent yards and a condo a bit off to the side of where the antenna has been aimed. I believe that I am somewhat in the low part of a valley.
I wasn't told the model of the 8-day Channel Master antenna, but the pre-amp is a Radio Shack antenna-mounted high-gain signal amp, model 15-321.
Raising the antenna height by a few feet will cost an estimated $110-160 parts and labor. I suppose I ought to just do it and be satisfied with what I've got unless there are other recommendations. Thank you!
bimr8 is offline   Reply With Quote
