Old 4-Nov-2015, 7:06 PM   #9
Would these still be your recommendations for antennas?
Yes, but I would like ADTech to double check my analysis in case I overlooked something. There are many factors involved, so you will need to continue with the experimental approach. I don't want to waste your money, so you need to go step-by-step.
Would attaching it to the chimney be okay, or free standing on a mount?
A chimney sounds OK if it is in good condition. An eave mount might be easier. I can't see what the building and the trees look like. You could try a temporary test outside before deciding.
