Tv Antennas and Reception
You can do this with the antenna you have . Here are ways to reduce multipath. Directional antennas have less reception at the , top , bottom , sides and back of the antenna. . Tipping Out Multipath . Tilt the front of the antenna down , this will put more of the reflected signal to the top of the antenna where there is less reception. Tilt the sides of the antenna , left side down - right side up or right side down - left side up. The sides of the antenna can be tilted up to 40 degrees and still receive the main signal that is received at the front of the antenna. Also can try rotating the antenna to the left and right.
