Old 2-Nov-2015, 9:41 PM   #3
rbanke
Originally Posted by Jake V View Post
Your TV Fool Report shows you have strong signals coming from the west. The RCA ANT751R is usually a very good antenna for your situation.
It this happened to me the first thing I would do is to check the connections. It is quite possible that a connection has come loose. Since you mention that it happens on all televisions, I'd especially check the connections from the antenna to the splitter. Weather can degrade the connection at the antenna or the bauln maybe faulty.
If that does not help then try bypassing the splitter and send the signals to one television and see what happens.
I should have mentioned, I have already checked and retightened all the connections as necessary. I'll give bypassing the splitter a try. There is also a grounding block before the splitter I forgot to mention but I'm guessing they are too simple to go bad as long as they're not corroded. I'll bypass it also for the test to be sure.
Thanks
rbanke is offline   Reply With Quote
