Old 2-Nov-2015, 6:30 PM   #1
rbanke
Signal dropping out
Hello, a few years ago I received some excellent help in choosing an antenna and it has been great up until a few months ago when reception of some channels started cutting out. Trees in the neighborhood have grown and Florida can be tough on equipment outside so I'm here to ask for some advice before I go and purchase a new bigger antenna.
Original Thread
Updated Analysis
Currently I have an RCA ANT751R pointed at 292 magnetic north mounted outside at the peak of our house. coax runs to a 4 way 5-900MHz splitter (outside within the cable box) and then to 4 tv's. Dropouts happen on all tv's and seems worse when more than one tv is on but that may just be my imagination. I was considering purchasing one of the other recommended models from that original thread but noticed one of them is no longer produced. I also saw the 'Flatwave' outdoor antennas on Winegard's site but don't know if those are better or worse than a 'normal' antenna. Powering the flatwave antenna should not be too much of an issue if it's substantially better to have.
Thanks in advance.
rbanke is offline   Reply With Quote
