Old 1-Nov-2015, 5:13 PM   #6
skatingrocker17
Manuel, I posted a question on the forums a few months ago about a problem I was having on certain days with my signal being 100% and suddenly dropping to nearly 0% for a few seconds then back to 100%.
Someone mentioned it could have something to do with us living near the airport. On certain days with wind direction changing, it could cause more air traffic over Canton. So while my signal is nearly 100% all the time, on some days it will shoot down to 0 and back up to 100 within seconds. I think the air traffic could be causing this.
Also, with a split run of 80' from your antenna I would definitely looking getting a distribution amp. Either a 2 or 4 port depending on if you want to hook up more TVs in the future. If you look on Amazon, The PCT branded one and Channel Master one are different prices, but they are exactly the same. The description on the Channel Master listing on Amazon even says "Channel Master distribution amplifiers, manufactured by Channel Master's former parent company, PCT International". So I would buy the cheaper one.
skatingrocker17 is offline   Reply With Quote
