Old 29-Oct-2015, 1:10 AM   #3
billfr
Hello Jake V,
Thanks for the quick reply.
The roof is asphalt.
The house is all brick, although the soffit has been covered by aluminum.
It is relatively flat here and there are no buildings of any size. All residential housing.
There are some mature trees in the general direction of the towers. The trees are not on my property, but on my neighbors.
I will continue to experiment with re-aiming the antenna a few degrees at a time. I have been using the compass on a smartphone, would you suggest a different compass.
I will post again after experimenting with different positions for the antenna and/or installing one of the antenna's you have suggested.
Thanks again.
billfr is offline   Reply With Quote
