OTA and Cable Channels Problem
I am having a problem receiving both over the air and cable channels on my Panasonic Model TC-26LX600 TV that I purchased 5/30/07. It has only one input for OTA/Cable. I tried a coax two way switch. It didn't work. I contacted Panasonic and was told I would have to re-scan each time I changed from OTA to cable or vice versa because the tuner was not engineered to hold both in memory. They further stated the only way to avoid this was to use a cable box or a VCR/DVD player. I would like to avoid both. Does anyone have any other suggestions to avoid this? Is there anything available that is small/compact with a tuner that will work?
