Old 28-Oct-2015, 6:00 PM   #5
Tower Guy
Originally Posted by hsparks56 View Post
So you think I should go with Antennas Direct DB4e or DB8e?
Thanks
hsparks56
I'd opt for the DB-8e. You'll need the extra gain for CBS. WRGB (CBS) on channel 6 is not that feasible as TVFool does not add extra low band noise to the NM calculation.
The VHF antenna for WMUR is necessary as it adds the local news. If you have the new style Channel Master preamp you'll need a UVSJ to add the VHF and UHF antennas. WCDC (ABC) should work too, but it will mirror WMUR's network programming.
Should NBC from Boston or Mt. Ascutney not work; W38DL is also NBC from Albany, NY.
