Old 28-Oct-2015, 12:44 PM   #3
hsparks56
NH Fringe Area
Thanks for the reply Rabbit73, I have attached my link to my report for you, you were very close! I have an old Channel Master antenna not sure what model it is, its about 6ft by 6ft UHF/VHF. Put it on the roof temporary to see what I got with no preamp just direct 25ft cable to my tv. got channels 11.1, 11.2, 11.3, 41.1, 41.2, 41.3, 62,1m 62.2, 62.3, 63.4, by turning antenna by hand didn't play with if that much but the channels came in crystal clear. I notice it pick up 5.1 and 5.2 ABC I think but TV was black.
This is about 10ft lower then I will put it. It will be 30ft from ground level when done.
I do have a CM-7777, I have a CM rotator too.
So you think I should go with Antennas Direct DB4e or DB8e?
Appreciate the help and would like to cut the cable!!!
Thanks
hsparks56
hsparks56 is offline   Reply With Quote
