Old 17-Jan-2011, 9:59 PM   #7
Tower Guy
Originally Posted by gimmeagig View Post
Would it be possible to connect a second antenna( maybe even just a cheap indoor antenna) together with the first one and point it to 230 degrees(for CBS), then merging the two antenna signals with a 2 into 1 adapter going into the DTVpal?
Yes, a second antenna is a good idea. No, a backwards splitter isn't the optimum choice to gang the antennas. Use an A/B switch to pick up the local PBS. Any un-amplified UHF only antenna should work fine.
The stations at 230 magnetic would be best picked up with a HD7698P and no amplifier.
