Old 26-Oct-2015, 2:42 PM   #2
Jake V
Welcome, jds_innc!
You did not enter a value for the antenna height when you created your TV Fool Report. Can you please prepare a new report with the intended height of the antenna?
Also, where are you hoping to put the antenna? Outside on the roof? In the attic (attics can be challenging)?
From your current report, you have both high VHF and UHF signals, so one of the larger combination antennas pointed at 25 degrees on a compass is likely the solution. But a more accurate TV Fool Report is needed first.
Jake
