Old 25-Oct-2015, 1:13 AM   #8
Dockell
rabbit73:
It's mounted vertically, attached to a beam in the attic. I tried adjusting the dipoles, but still got nothing. There is power in the attic for the antenna, but I don't see any way to adjust the amplifier other than by plugging it in. I did get (and still get) WNEM.
Spencer:
How high above the roofline would you recommend? I can't attach a mast high enough to clear the trees - is just having it outside going to make that big a difference? I could try and attach it to the chimney, but I'm hesitant due to the strong winds we sometimes get through here.
Dockell is offline   Reply With Quote
