Old 24-Oct-2015, 11:53 PM   #2
The stations I really want are WRGB Real Ch 6, WNYT Real 12, WTEN Real 26, and WMHT Real 34… all at 184 degrees.
That list makes the all-channel antenna mandatory unless you can actually pick up WCWN reliably. The VHF 6 channel will be far more reliable when on the back side of a hill in the forest, FWIW.
but I don’t see that sub-channel on the report.
No sub-channels are included in the TVFool database, only the primary (.1). Visit http://www.rabbitears.info/market.php and scroll down to market #45. That listing will cover what's in your area in great detail.
all of the 5 stations I want are blocked by a giant 80-100’ Elm tree with about 8 thick branch trunks (12”-16”+).
Make firewood or accept whatever happens. Yep, I'm that cynical. I loose several stations every summer. I've hit MY limit on what can be done and there's nothing more to do. If you're on the back side of a hill and the signal has to go through trees to get to you, do NOT expect (but do be thankful for) perfect reception. It is simply impossible to predict what will happen.
