Old 22-Oct-2015, 11:22 PM   #6
GE 24802 Indoor Antenna
This semi-directional HDTV antenna has a built-in amplifier that you can adjust to match your needs. Plus, it has retractable dipoles and UHF loop for improved performance. Its compatible with VHF, UHF, HDTV and FM. This indoor TV antenna has a set top mount, so you can place it in any convenient location.
UHF Loop, Retractable Dipoles, Indoor, Built-In Adjustable Amplifier, 75-OHM
UHF Loop Reception Channels: 14 - 69
VHF Dipoles Reception Channels: 2 - 13
Amplifier Gain: 20dB
Do you have it mounted vertical or flat horizontal?
The setup worked well for a little while, until the leaves on the trees started coming in (the neighborhood is full of mature trees), whereupon I lost WJRT and WXYZ.
WJRT is on real channel 12 which uses the dipoles; did you adjust them?
WXYZ on real channel 41 is a UHF channel that is much weaker than your channels in green and in a different direction from the SE. Did you adjust the antenna aim for it?
You need at least one of those two for ABC.
The specs say that it has an adjustable amplifier. Does that adjustment make any difference? Is there power in the attic for the antenna?
Did you ever get WNEM for CBS?
I'm thinking maybe the GE 24792 Attic Antenna with a preamp that wouldn't be overloaded by WCMZ. No guarantee that it would be any better because of the trees.
