Old 20-Oct-2015, 12:45 AM   #3
Hobiecat
Rabbit73,
Thank you for all the good information.
The satellite dish mount has two braces on it. I ordered a 39 inch mount that bolts onto the satellite mount bracket. I will extend it enough to clear the roof top. I also plan to remove the dish, and LNB to reduce the weight on the mount. Do you think that is enough, or should I look at alternate methods.
I just plan to use the dish coax which is grounded to the house electrical ground wire. Can I run a parallel wire, connected to the mast, and ground it to the same electrical ground wire? Will the 7777 continue the ground to the antenna?
Appreciate all your help.
Hobiecat is offline   Reply With Quote
