Old 19-Oct-2015, 8:09 PM   #11
If there is still too much difference in strength between WSAW and W27AU, you can make WSAW and WAOW weaker by attenuating VHF only:
Code:
                              10 dB
                            attenuator             TV 1 needing strong signal
       outside            V/         \V             /
Ant > grounding > coax > UVSJ       UVSJ > FM > CM3412           TV 2
       block              U\         /U   trap      \           /
                           coax jumper             2-Way Splitter
        TV 3
The first UVSJ separates VHF and UHF so that they can be treated separately; the second UVSJ recombines them.
May be a station issue. Hopefully something they can resolve.
Can you call the W27AU station engineer? Since W27AU is a translator, you might have to call the master station WJFW.
http://www.wjfw.com/contact.html
