Old 19-Oct-2015, 12:32 PM   #11
bimr8
update: my reception results
Just wanted to give an update on my TV reception after installing an 8-bay antenna about 30'-high aimed directly towards Boston, along with a pre-amp. My condo sits in a fairly low spot near the Merrimack River and the antenna shoots through a few trees. The antenna was installed by a firm out of southern NH that does many installations ... they recommended and installed the 8-bay Channel Master antenna and a pre-amp. I am receiving about 39 stations including ABC, CBS, NBC, PBS, and FOX. Channel 7.1 (NBC), the weakest station of interest to me, is being received mostly without pixilation, although pixilation occurs once every few minutes. The antenna installer says that reception of channel 7.1 would improve if the antenna were located 10' higher. The picture is otherwise beautiful!
Thanks for all your help and suggestions! I am satisfied, but may still raise the antenna height.
bimr8 is offline   Reply With Quote
