Old 18-Oct-2015, 5:42 PM   #21
Originally Posted by FrenchConnection View Post
So what this seems to be telling me is that there could be KTMF signal at my mast location, but without the added strength from the reflection the antenna doesn't pick it up.
2) What numbers do I need to get from the Stacker manufacturer on its UHF gain to be able to compare with other UHF on the market? (i.e. if they tell me that its UHF gain is ~10 db then I would think I need something 20-30db gain to pick up a signal at my current location).
FC
Correct.
The estimated gain of the HD Stacker of 10 db seems about right. It's UHF section is similar to the Winegard HD9075P. Here's the data on that antenna.
http://www.solidsignal.com/pview.asp...0Antennas&sku=
If the ground reflection is the ONLY difference, you'd need an antenna with 6 db more gain than the Stacker if installed at your less than optimum location. That narrows your selection of antennas to the 91XG (or one of the clones of that design) or a DB-8e.
https://www.antennasdirect.com/store...V-Antenna.html
