Old 18-Oct-2015, 4:46 AM   #1
NotAnEngineer
First time installer in Durham, NC
I’m new at installing TV antennas (and at most “do-it-yourself” electronics) and would appreciate some help/advice. Here are my TV signal analysis results from TV Fool:
http://www.tvfool.com/?option=com_wr...8e0361cd787b03
Short version, I want more channels, and I’m debating between buying a pre-amplifier or getting a bigger antenna.
I’m in a one story house in Durham, NC, surrounded by a lot of tall trees (much taller than the house) planted closely together, and 30 miles away from some of the towers of the signals I want to pick up. I went from an indoor Mohu Leaf 30 in my living room to an RCA ANT751R in my attic (50 ft RG6 coax), but it didn’t give me any more channels (I’m getting 4 channels plus the substations). If you look at my report, I’m getting PBS (25), Univision (38), ABC (11), and NBC (17), but I also really want to pick up CW (27), CBS (48), and Fox (49). The thing that I find especially puzzling is that I can pick up NBC but not Fox or CW, because on the map they look like they are all three originating from the same location about 30 miles away.
Any help/advice (including criticism) would be greatly appreciated. That being said, I want to avoid mounting the antenna on the roof instead of in the attic because a) I’m renting and planning to move by summer 2016, and b) it seems a lot more complicated safety-wise, and I don’t want to screw it up. As I mentioned before, I’m looking at pre-amplifiers (perhaps high gain because of interference in the attic and from the trees?) or buying a bigger antenna. Thoughts/comments?
NotAnEngineer is offline   Reply With Quote
