Old 17-Oct-2015, 11:29 PM   #5
With the DB4, would I be able to point one of the bow ties toward Tallahassee and one toward Panama City?
No, don't try to separate them, they need to work together for max gain.
I don't think I can guarantee reliable reception of WECP; it would be an experiment. At the very least it would require a separate high gain antenna, preamp, and feedline, aimed at 292 degrees magnetic. Two UHF antennas are not easily combined, so you would need an A/B switch to select which antenna to use, or connect it to a separate TV or tuner and connect the output of the tuner to the aux input of the TV.
WFXL is even less possible because it is a Tropo signal, but to its advantage it is a VHF-High signal which can travel over difficult terrain more easily than UHF signals and its antenna can be combined with your UHF antenna with a UVSJ.
To be frank, your expectations would be difficult meet because those two signals are very weak, and of poor quality. Another problem is that a high gain preamp would be needed for them which would be vulnerable to overload from your much stronger local signals.
