Old 17-Oct-2015, 10:04 PM   #4
Mike1953
Antenna coverage
Thanks for your input. First of all, the cheap yagi I have is pointed to 335 degrees. The main station in Panama City I want is WECP. It doesn't show as CBS but is. I like that channel because Panama City is central time and Tallahassee is Eastern, so being retired, if I oversleep and miss the CBS morning news on Tallahassee station, I can get it on Panama City. At 335 degrees, Tallahassee comes in fine and Panama City comes in intermittently.
With the DB4, would I be able to point one of the bow ties toward Tallahassee and one toward Panama City? I assume the RG6 screws in the DB4 so I will have to run a new line since the yagi is built in to the rotor.
Also I like that it does not rotate and looks like the birds would leave it alone- not much of a place for the little critters to land.
If the cheaper DB4 is made of aluminum, it would probably stand up as well as the higher priced stainless steel one.
Thanks again for your help. I would really like to be able to pick up WFXL in Albany so I could get Georgia sports, but I guess 91 miles is too much to ask.
Thanks,
Mike
Mike1953 is offline   Reply With Quote
