Old 17-Oct-2015, 8:03 PM   #3
I suggest the Antennas Direct DB4e, which is a UHF antenna for real channels 14-51. It's beamwidth is about 50 to 60 degrees, so you will need to rotate it. You might be able to aim it between 317 and 26 degrees true for the first 5 channels if you don't want to rotate it.
https://www.antennasdirect.com/store...v-antenna.html
http://www.bestbuy.com/site/antennas...&skuId=4875742
They also make the DB4-PRO Grade Signature Series Bowtie HDTV Antenna with stainless steel for costal areas, but it is a lot more expensive.
https://www.antennasdirect.com/store...V-Antenna.html
Try it without a preamp first. If you need more gain add the Channel Master 7778 preamp.
The Panama City station paths are 2edhe not the 1edge I mis posted.
Which Panama City stations are important to you, by callsign? They might require extra effort.
