Old 17-Oct-2015, 4:03 AM   #9
MikeBear
Originally Posted by Cash_Mayday View Post
Thank's, I'll add some to the list. Should it be outside at the antenna, or inside at the splitter or does it really matter?
In your case without an amp, it can be inside BEFORE any splitter. So you will need a short coax jumper for later when you add the splitter. The traps aren't polarized, so can be hooked up either way. Sometimes people need to put TWO of them in series. I suggest you might be one of those, so get two jumpers or a male/male F connector to join them.
I highly recommend you concentrate on getting things working with a single tv set first with no splitter.
Code:
 Antenna ---> FM Trap ---> Tv set.
That makes things much easier to trouble-shoot, if you encounter problems.
Once you know how that works, you can reconfigure for a second tv set.
