Old 17-Oct-2015, 3:18 AM   #4
MikeBear
Go up to FMfool.com and run the report with the same settings as your Tvfool. Then post the image of the report here. The url for that won't link through, so you must post it as an image.
45 degrees is doable in many cases with a single antenna, you typically aim in-between the stations for that. I'm aimed between my UHF stations, and am receiving a 60 degree spread using an HDB91x antenna. That antenna is WAY overkill for you though.
