Preamp??
With those high signal levels, a bent paperclip stuck in the back of your tv set should get all 7 stations from the top!
Install an antenna that's good for both UHF and high VHF, aim around 320 degrees magnetic and run it to a single tv set. See what happens. Then you can consider splitting it to another set. I think your Ant751 would be a good choice for starters.
