Old 16-Oct-2015, 8:06 PM   #14
MikeBear
Originally Posted by FrenchConnection View Post
Appreciate the help MikeBear.
I understand the pre-amp disconnect, and that shouldn't be an issue since I can use a single line splice at the mast, and connect directly to the tv in the house.
For the second UVSJ I will look for Radioshack Model #15-2586.
If I go with the KT-200-Coax, I believe I need to provide protection from the elements. In your case, did you use an OTC product or modify a telephone or other junction box?
Thanks again.
FC
I bought and used one of these. http://www.homedepot.com/p/Commercia...4-CE/205727789 I screwed a flat plate on the back/bottom, and used a couple hose clamps to clamp it to my mast under my antennas. It has enough room for the Kitztech, FM Traps, and even the UVSJ if you choose to put them all in the box.
I drilled a couple holes on the cover as needed to pass through the coax, and sealed it with 'Coax Seal' where the coax's pass through. You can buy that from Solid Signal also. It's a moldable plastic material, that resembles black tar. It seals connections tight and waterproof, YET, it can be peeled back off when you need to. One of the greatest products that was ever invented!
