Old 16-Oct-2015, 11:54 AM   #12
FrenchConnection
Appreciate the help MikeBear.
I understand the pre-amp disconnect, and that shouldn't be an issue since I can use a single line splice at the mast, and connect directly to the tv in the house.
For the second UVSJ I will look for Radioshack Model #15-2586.
If I go with the KT-200-Coax, I believe I need to provide protection from the elements. In your case, did you use an OTC product or modify a telephone or other junction box?
Thanks again.
FC
FrenchConnection is offline   Reply With Quote
